Hi all,
I need a regular boiler urgently as my 16 year old Vaillant has seized. I am looking to swap it with another Vaillant in 30 kw and have been recommended the Ecofit Pure and the Ecotec Plus regular boilers. I believe I have to settle with Aluminum heat exchanger as there aint many options in Stainless Steel in the regular/conventional boiler option. Both of the above Vaillants have aluminum heat exchanger in the regular boiler option.
Can I take your views on which of the above I should go for and why? Are there any differences between the two? Or if there is anything else you would suggest?
Thanks in advance
Thanks in advance
