Hi guys, my first post here, but I won't lie, I've used this place as a reference point so many times it's been invaluable, so I thought I'd sign up and ask a question I have. I will give as much info as possible so forgive the long read...
Last week the pump on my mom's boiler went, as per the title it's a Vaillant Ecotec Pro 28. I contacted a local parts place who were very helpful, and after I gave them the gas certification number on the boiler, the part came up and I ordered it.
Today, I finished work, collected the part and proceeded to go and change the pump. All went well, no issues during installation, and so after filling the boiler back up I turn on the electrical supply to the boiler. This is where things took a turn.
The green light comes on, the LCD display shows 2 dashes, there's a very faint click within the PCB area, and it then proceeds to shut off (green light goes of and display is blank), all within about 1 second. I have a video of this and can upload to YouTube if it helps.
Now, the thing I've noticed is that the pump removed had a 3 wire multiplug. The new pump has a 5 wire multiplug. The PCB has a socket to receive a 5 wire multiplug. When I was researching prior to choosing a local parts place, I had read about there being 2 different brands (Wilo and Grundfos), and with the latter being an improved pump, my assumption was that this was part of the upgrade, the PCB takes a 5 wire multiplug and I had given the exact number for my boiler to my supplier and they provided the exact pump I needed.
Clearly now, I am fearing the worst that I have potentially blown my PCB by using a pump it can't handle, despite the allowance for the plug it has and my confidence that I was provided the correct part for the exact boiler. And of course doing a search for "5 wires" shows adverts for the pump stating "5 wires only".
I'm going to call my supplier tomorrow for their opinion, but I'd like your input too so I am armed with as much info as possible. Prior to fitting the new pump the boiler did fire up and try to work so all was well apart from the pump being broke. If I now plug the old pump in (despite not being plumbed in) it still does the same thing. I changed the fuse on the PCB too in case that had blown during the switch on process (tried both the spares attached the the plastic casing, there's no guarantee they were both ok, but I would be confident they haven't been changed prior and so expect them to be ok).
What do we think has happened? And...
1. If a new PCB was ordered and replaced would that suffer the same fate?
2. Are there other parts on the PCB that would prevent correct operation of the boiler if it were to match the 5 wire pump setup?
3. Am I missing some kind of reset procedure to get it working?
4. What would my rights be now that I've fitted the part and filled it with water but was not asked or offered whether it was 3 or 5 wires?
5. What's my next step?
My regret is that I didn't stop when I noticed the different wiring setup, contact the supplier and double check it would be ok, as I said, my assumption was this would be ok seeing as the board could take the 5 wire plug and I had read about the pump being upgraded. But my mom has had no heating or hot water for 5 days now and I was eager to get her back up and running.
ANY advice and thoughts welcome. Thanks in advance.
