Had a Vaillant EcoTech 831 installed to replace a conventional boiler. Initially rads upstairs were OK but most of downstairs very very slow to heat up (several hours) with 1 not working at all. Now a few days later all of downstairs not working after 3 hours running and 1 upstairs not working also. Hot water is OK.
Pre-installation they did a power flush and have done one subsequent to the installation but as I said things seem to have got worse.
All rads were working prior to installing the new boiler (a few were slower but would reach top temp within an hour)
Not sure what to do now. Is it reasonable to get the fitter to resolve without paying extra? We've shelled out a load already. We seen to be just throwing money away with no resolution. (he is corgi registered) He says the existing pipework was a bad design (we have an extension prior to when we moved there) which it may have been but it use to all work with that pipework so why not now. He also says some gunk may be lodged somewhere but I would have hoped the flush would have sorted that out.
Some rads are hot at the flow pipe entering the rad but the rad it cold and so is the return out of the rad. Have tried bleeding all rads also. The flow pipe from the boiler it hot and the return is somewhat warm also. He says he balanced the ones upstairs that were getting hotter qucker to improve the flow to the ones downstairs that wern't heating up.
Im wondering whether when they cut out existing pipeing or bypassed something which has caused things not to work properly.
Any advice on how to proceed and what to expect from the fiiter is greatly appreciated!
Raj
Raj
