But there are plenty of installations which have TRVs on all rads and no TRVs (enough posts on this site on this subject), so I was just checking that your's wasn't one of them.There obviously isnt a TRV on the rad where the thermostat is located. schoolboy error isnt that one?
That's what they all say.The CH output wasnt taken into account as i was told the boiler was more than capable of coping with size of house.
Makes you wonder if he knows how to do the job when there are TRVs on the rads.I called the gassafe engineer today and he told me he actually balanced system to try to address issue.
But the boiler is cycling. When the set temperature is reached, it should be modulating down so that the heat produced is just enough to maintain the water at that flow temperature.The boiler doesnt seem to be cycling exactly as you say. It fires up to the temp displayed on the boiler, cuts out when it reaches that temperature then only comes back on when temp drops significantly.
Yup! And as I suggested earlier, the installer does not know how to balance systems with TRVs.I turned on system whilst i went out and turned down all rads upstairs via the TRV's. When i came back the Rads downstairs are all getting much warmer (fully opened) but not with the intensity of upstairs rads. seems with prolonged usage it is getting better but the issue is still there. Im guessing as said many times earlier this points to a balancing problem.
Not yet! There is a possibility that your boiler is unable to modulate low enough!Lastly - Can i close book on rating the boiler? seems like it isnt required?
You have hit the nail on the head; it's all about the first fire. The problem is that every time the boiler restarts it is treated as a first fire so, if the water gets heated up faster than the rads can dissipate the heat, the water temperature will rise to quickly and the boiler thermostat will kick in.Range rating helps the boiler perform better by capping its maximum on first fire but not doing it will not cause any problems.
If you don't think this will cause any problems, there are plenty of cases on here where the problem was resolved by capping the maximum output of the boiler.
Well this is getting a bit tetchy isn't it?
I've seen more than a few installations where Vaillants haven't been range rated and if the difference between flow and return is too big they go to S.53.
DM himself posted a while back that they need rating to avoid this.
Not bothered to read the whole thread and it could well be a circulation issue but flaming D Hailsham seems a bit childish to say the least.
Most systems they work fine on right out the box but I've fitted them on all 15mm systems with 7 or 8 rads and they need rating to minimum output in order to work.
In any case as it would only take the OP 30 seconds to rate it down to 12kW or so what has he got to lose?
Close all the lockshields with a spanner and then open each one just ONE whole turn downstairs and 2/3 turns upstairs.
Set the boiler maximum output power on d0 to 12 kW.
Tony
I've not read all of this thread, so has he been asked whether it's a microbore system, drop fed from a manifold.
