Hi ladies and gents...
For the last few days I've had error 75 on my vaillant ecotec pro 28 boiler. Bleeding the rads and resetting the boiler got me 24 hours of use but then the problem returned.
My usual plumber has kindly called in to look at it on his way home but as he doesn't usually do repairs he wants me to choose the next step in the repair process. He thinks changing the pump will fix it but it's not definite. He thinks it's the pump because the pressure display rises by 0.2-0.3 bar when the pump starts but it seems to sometimes not quite create enough pressure to fire the boiler. We actually watched the pressure rise on the display but not hit the magic number and on the occasions it hit the pressure needed the boiler fired.
Does the pump seem the likely culprit or should I try some cheaper options first?
Thanks for your help.
