I hope someone more knowledgable than myself can help with this query.
Re the Vaillant VRC 430 weather compensation units, there is a setup menu option for using this with "no thermostat", "modulating" and "thermostat".
Does this mean that if for instance I have my boiler in the garage and fit the VRC430 in the boiler I can set this menu item to "No Thermostat" and the inside room temperature can be selected by changing which heating curve I use? The only temperature reference then being from the outside sensor.
The Danfos devices seeem to work in this way but not clear from the Vaillant Installation PDF if the VRC430 can work do the same thing.
