I thought the latest version of VR470f did have some sort of heat curve auto learning feature whereby it automatically adjusted the curve once it had learnt the heat up/cool down characteristics of the building?
the wired vr470 has auto heat curve, also the vr700 is now on the market, does the auto heat curve etc & has an app but in typical Vaillant fashion there is no detail on how the app connects to the controller, i suspect a separate module is required.
looks like the vr900 is the internet bridge for the vr700, there is a wireless adapter for the vr900. I don't think the vr700 is wireless.
The heat curve is essential to maintaining correct temp in your house, not too hot (curve too high) and not too cold (curve too low). The wired controllers will calculate this for you if the newer vr470f does this then great but how do you know what revision you will be shipped? I've had to up the curve on vsmart as boiler was on all day & house nether reached target temp.
A proper vsmart app update could make vsmart the one to get but so far its pants. Try the apps for yourself and see what you like or don't, really depends what you want.
the VR470f would be perfect if it did auto heat curve, easy water or heat timer boost & more temp settings per day. Vsmart allows more temp settings per day, easy water and heat boost, auto heat curve (either limited to 1.4 or takes far too long to up its curve) but removes the ability to : set separate HW and heating timers, threshold before heating cylinder, display outside temp on e-ink controller, use actual outside temp instead of internet weather temp, see boiler info like flow & return temps plus others i don't remember. If you need non of that then wired controller is likely better. Have a long hard think before committing yourself, check the Vaillant controller simulators and be happy with what you decide to get.
Good luck,
worth trying vaillant tech support for any Q's you have.
Thank you for all your support (and apologies for delay in replying).
Essentially I want boiler modulated output according to outside temp, with remote access (i.e. mobile phone or tablet).
It seems vsmart does this but I'm not happy that it uses internet received temps rather than actual outside temps.
Plus I'm reading quite a bit of negative press on it (you guys on here for example).
So I don't think there's anything out there for me yet. The 700 from vaillant looks to not be available in the UK yet. Plus I don't think it gives remote access ?
Guess I just need to wait until vaillant release their latest version of hardware?
