Valiant echo tech 624 rad sysmbol always on
Can you not get your engineer back if the fault has developed since he touched it?
That is the problem he is not responding anymore
So I have left with two option
Either I call new engineer to check pcb 24x connection
Or
Replace the divertor 2 port valve head
Which one should I try first just to keep the cost down?
You wanna keep the cost down get a "decent" engineer out to look at it. wont be more than one visit.
FYI F22 has almost certainly had nothing to do with old PCB, and the staying on constant probably is related to new PCB.
Or
As per @ScottishGasMan said get a “decent” engineer and get him/her to check the pcb (probably the cause) and if it’s not that get them to check the 2 port.
F.22 is usually low system pressure, would be interested to know how it was diagnosed as a PCB. Do you know how to check and top up your system pressure?
Or
Why do you think that constantly throwing parts at your boiler and system will solve your problem ?
We have to replace pcb because boiler was locking out everytime we reset and ends with f22 error after replacing pcb f22 error stopped, so replacing pcb is correct thing to do
Just spoke valliant support they said permanent rad symbol means it's ready to operate buts it's not actually heating anything is this correct?
