Can someone shed light on the following? The plumbers I have talked to so far do not have the answers...
I know that combis are rated e.g. as capable of raising 20l/min by 35 degrees, and it is always said that there is no point having a boiler that is rated higher than the water flow available (i.e. in this case at least 20l/min). But surely, having a boiler that is more highly rated than the flow would allow the water to be heated hotter, which would effectively allow more useful water out (e.g. when the raise needs to be more than 35 degrees, which it often is). i.e. Is it possible to fit a larger combi and get more of a temperature lift from lower flow (which would help e.g. for 2 showers at same time in winter)?
Also, can someone clarify whether the Valliant 937 is really a 20l/min or 15l/min boiler in terms of input flow. It has a tank (which is an attraction for various reasons), which if I understand correctly is heated 'offline' (like a normal system tank), and can then be mixed with the directly heated (normal combi style) water to provide an output effectively of 20l/min until the tank runs out, then is rated at 15l/min. Am I correct in thinking that a house flow rate of 15l/min is then really what is required, not 20l/min as usually suggested?
The house I am interested in putting the boiler in has a flow of 16l/min and pressure 2-3 bar. It has one bathroom at present, but we intend to add an ensuite. We are shower, not bath, people.
Would appreciate any answers...
Best wishes,
Salmoner.
Best wishes,
Salmoner.
