Hi everyone
I have a Vaillant thermoCompact 637E. If I set the flow temp on the boiler dial to say 67 it only gets up to 61/62 on the display. If I set it to say 72 it sits around 65/66. I've balanced the system and aimed for around 10-12 deg differential on the rads. When checking the differential at various times on the boiler diagnostics it seems to range between 10-15 deg.
Is this normal behaviour for the boiler display to always be 5-6 deg less than the value you set?
I have an infrared thermometer and it seems to suggest something around 70-74 deg when measuring flow side of rads. I know this maybe answers my question but I am curious to understand if this behaviour is right.
Many thanks
Many thanks
