You n check the power input at the gas meter yourself. Look at the FAQ on this site.
It would also be good if you could learn to talk in kW as they are the units the UK has used since 1980.
The gas rate measures the input power and that will be higher than the output because your boiler is not very inefficient.
When did you last have it serviced?
Tony
Tony
