The manufacturers would state an annual combustion (emissions) check and then only a service if unsatisfactory results. This could mean all ok for years until all not ok. In my opinion this leads to premature failure as the heat exchanger is not robust enough and I would advise a full service, each year, as a minimum!
I have seen these not touched for 4 years looking better than some after 1 year. Point is you can't tell without opening and then replacing expensive seal.
Your alternative is to replace the boiler with something that doesn't use that heat exchanger. Intergas make an 18kW model which will directly replace yours. It's heat exchanger is in a different class.
