I just wanted some help like i say im no electrician and i understand most people are here to help i did not know i had to buy another dimmer slave i thought it world work on a rocker switch .....so no need for some people to take the p... Cheers Breezer
Sorry - this doesn't wash. You do not have to be an electrician to be able to understand this:
"Your VARILIGHT Remote Control and Touch Master Dimmer is suitable for 1-way circuits.
It can be used for 2-way circuits only if wired as shown below and using a VARILIGHT slave unit."
Geez if any of you worked in IT support like me, you would have exploded. Do you know how many calls I get from people who say "my computer's broke" and it either:
1. Isn't on
2. Isn't connected
3. Explained what was wrong in an error msg which they closed and ignored.
It's frustrating, but you have to just point it out once, and let it ride!
I used to work (some of the time) on a helpline. We had this internal problem tracking/activity reporting/time recording/resolution recording software that we used.
A new manager decided it'd be really neat, when an incident was closed, to send the customer a copy of the report, showing him all the effort which had been expended on his behalf.
He didn't tell us he was doing this.
One day he got a call from a customer asking what the resolution "RTFM" meant....
I've wired up the varilight switch, and it works really well.....
except that the light never actually turns off, it stays on really really dim, any ideas?
I should say its the master, since the slave only tells the master what to do. (you could isolate the slave and see what happens)
The other thing is if you do not have ENOUGH load (not enough watt of lamps) this may also cause the lamp to glow, if so it is normal, and the only way round it is to use bigger lamp / more lamps
to be honest about it i personally do not think much to them, especially after a piece some one posted on here, it confirmed what i thought, trouble is i can't remember where the piece is
