Vauxhall Vectra Exclusive Timing Belt
12 Feb 2005
Hi
Can anyone tell me if the timing belt of a Vauxhall Vectra Exclusive should be changed around the 70K miles range. A seller is telling me these models are fine until the 100,000 miles range because the a designed using a chain.
What engine is it? If its chain it will never need changing unless it is faulty/noisy!
Not strictly true, as they do stretch and the tensioners give up after a while
Thanks For the replys
The engine is 1.9 cdti. Is this the information you need?
