I had to go bankrupt almost 2 years ago and lost my vw transporter in the process, now with £1500 im looking for a cheap vivaro but even if i find one at that price they seem to fall to pieces years before! The internet seems to be littered with vivaros and the other 2 copies having all the same problems costing 3 times as much as im starting with. what a great start to the year.
Any suggestions on a reliable 'old' van?
Just found this on ebay...
Vauxhall vivaro 1.9 DI swb 2700kg van
with a problem as it wont drive over 30mph
Well i was in the same boat things went belly up on me and had to offload my traffic,had a 07 with 50.000 on the clock and never caused me a bit of hassle at all, really comfy to drive, so when i got a few bob together i went looking to get another trafic,spent a few days going through a few sites, eventually both 1 for 1600, 03 model, was running fab etc, but 3 months the engine management light came on and off, eventually 2 weeks later, i lost all power and could only do 30mph like urself, it turned out to mass air filter on the back of the manifold on the engine, but when we inspected the van a bit more we found it hadnt been serviced in quiet a while, so set about changing oil filters fuel filters, glow plugs, fan belt, timing belt, brakes etc which helped alot, getting back to the MAF, that was my problem at 1st it was clogged up and the tubbing had split with a loss of pressure, u can but 1 for 90 quid easy to replace i learned afterwards, if its not that try the EGR valve which can clog up with oil which is on top of the engine, u will see it when u remove the manifold from the engine, its connected to the exhaust manifold, sometimes it will be that, but also the wiring causes problems which turned out to be mine, because it runs acroos the engine under the manifold which causes it to be rubbed quiet alot, nbeing honest it still a good van, but i had to put an extra grand into it to get everything done because who ever had it before me didnt look after it, so i think wit a bit of tlc it will stand u time, but if i was u get all those things i was on about tchecked 1st, go to some small garage with a good mechanic because renault are crap, hope this help u a bit, any q's just ask, nearly know the van inside out at this stage.
