Vauxhall Zafira '02 making high pitched squealing noise
Mick,
Sorry to have kept you waiting :) It was the rear brakes that seemed to be causing the problem, as you suspected.
My mechanic stripped them down (took off drum etc.) checked the pads and discs - found that one of the pads seemed to have set solid in it's housing and was badly worn (90%). He also noticed that the discs had quite a big 'lip' on them so, rather than replace them, he took them off and lathed down a millimetre or so off each one. He fitted new Ferodo pads and (touch wood) I haven't heard a squeak since.
:D
PS. He did say that the discs will need replacing in a year or so, though.
Happy New Year.
Oops, nearly forgot - special thanks also to Strider as he (along with Mick) correctly identified the problem of the pads being seized in their housing/blocks.
Many thanks.
PS. Cost me £56 all in for the rear repair (including pads!)
