Hi!
Does someone out there who knows these old boilers tell me, if I draw hot water, should this cause the diverter to move into DHW position regardless of whether the micro switch clicks in?? In other words, is it purely hydraulic action that moves the diverter valve into place???
And, if this is the case, is it the servo valve that will likely be at fault (or one of the small tubes from it blocked?) if diverter not going itto DHW mode?
The diverter has been cleaned and a new diaphragm put in so I am sure that works fine.
Thanks!
Phil
Thanks!
Phil
