We have a newly installed Veismann boiler, our central heating works OK, but we cannot have hot water at the same time. It will only heat water but will not switch over to run the radiators. When our installer has tried to run the sytem as it is designed he can't make it work. We get Error messages saying F2. He has tried to get rid of the air in the system by venting the boiler several times but this does not solve the problem.
For the last couple of months we are using the boiler to run our radiators and we rely on the emmersion heater to heat our domestic hot water.
Can anyone suggest a solution please?
Thank you Simon for responding. It is a sealed system 4 pipe - Vitodens 100
