I have a fully pumped open vented system with a 3 port valve. At the point when the pump shuts off after the CH has been on, the system pumps over out of the vent pipe. It's like the sudden stop in flow causes a surge and expels a short burst of water out of the vent pipe. It does not appear to pump over at any other point when the CH is on, just when the pump turns off after the CH has been on. It also doesn't do it when just the HW has been on.
I don't believe there is any blockage in the cold feed from the F/E tank, as the system was drained a few months ago (to replace a couple of radiators) and it filled back up fine.
I'm not sure if the system has always behaved this way or not, as I moved into the house just a few months ago. Can anyone please advise on what could be causing it, and the consequences of the problem.
