Vent stack and soil arrangement on extension
I was assuming that the current drain runs up the centre of the garden perpendicular to the property therefore the inspection chamber is now off to one side.
Are you sure about the drain layout?
Normally drains run across the back of the houses.
I'll probably have to provide a soakaway for the rainwater then.
What does the existing rainwater pipe connect to ,can't you connect the rwp into the existing surface water branch drain ?
