Hi
I have just replaced a mid port valve in my vented system, But I cant fill the system at all. Tank in the lift didnt empty at all when I drained system.
Obviously there is a blockage in the system. Have taken the pump off and turned the valve between the tank and the flow pipe but not a single drop of water comes through. I think (but not sure) that the pipe is blocked with sludge.
Where the 15mm (from expansion tank) joins the 22mm (main flow to pump) there is what I can only describe as a trap made from "2" 15mm elbows and the 15mm enters the 22mm from underneath. (hope this makes sense) I can only imagine that this is blocked with rubbish from the system.
Have taken pipe off the valve in airing cupboard and water flows really fast.
My question is this. I am going to have to cut this section out and replace it. Does the 15mm supply pipe from tank have to enter the main flow pipe from underneath?
I hope this makes sense.
Paul
Paul
