What if a ball valve goes on a cold water cistern?
And if we humour this fannybaws
There would be more chance of a constructive discussion if anyone other than you had even the slightest inkling why you started it in the first place. Maybe you could give us a clue?And if we humour this fannybaws
If you were able to give clear and concise answers without being rude then a constructive discussion would happen.
If we aren't polite enough then Feck off and bore them.Don't tell me BG, you're a retired 'engineer', with too much Google time & too big a pension?
Trying to retire, but people won't let me.
Google is good but I also have access to other data sources that google does not have access to
A pension can never be too big.....
Obviously that is the immediate safety requirement but opening a pressure relief valve can have consequencesWhen a pressure relief valve opens, what generally happens is that excess pressure is relieved, thereby protecting the appliance.
I said:A pressure regulating valve did fail to control pressure and the results of that failure were the reason for the discussion starting on the other forum.
Maybe I should have asked for comments about the consequences of the pressure regulator failing leading to the opening of the safety pressure relief valve.
It is these consequential things that are being discussed politely and constructively elsewhere.
primatic or sidewinder cylinders
Yes there is a question. If the pressure regulator on the incoming mains supply fails and allows water at more than 4 bar pressure into the unvented tank what will happen ?.
It will be interesting :-
1/ to see the replies that are posted here and compare them with the opinions posted on the other forum.
2/ to see if anyone here mentions the sort of event that prompted the discussion on the other forum
Ruptured ( due to pressure ) or perforated ( due to corrosion ) ?Seen more ruptured vented copper cylinders then I ever have Unvented.
That is actually quite a comical statement, unless you have X-Ray vision or have cut the cylinder open.Seen more dead mice in cold water cisterns than I ever have inside an Unvented.
