I was just reading the back boilers-legal or not thread, where ventilation was brought up.
The flue on our worcestor combi was classed as "not to current standards" a couple of years ago, by BG. No work was ever done to it - before or after. They blamed it on a change in regs in 2005 - they had never told us it wasnt to current standards before.
Apparently there are new regs in August 2008 that mean some will be "at risk"? What criteria are changing?
For info, the flue in question is on an outside wall. Theres a window 20cm to the right, which has an opener 90cm from the flue.
There's a plastic drain pipe running horizontally above the flue (from the bath), which is shielded by a rusty metal shield.
The soil stack is about 20cm away on the left.
Would this be at risk? The flue is an old square mirrored-front one with the vents on 4 sides.
