I did not describe it properly.
My idea is to build a "box" inside which there is an AAV (durgo valve) (one way valve pulling air from the room but not allowing air to go into the room), then a "strong" fan, and then a pipe of some diameter which is connected to the soil pipe at the back of the toilet pan (at the top of course).
AAV, fan and pipe are sitting higher than then soil pipe so there is no possibility of foul water reaching the fan.
Expelled air will travel through the soil pipes until it escapes, typically through the nearest vertical soil vert pipe or through the sewers.
The problems that I see here, without having run a test, is how much air pressure may be inside the soil pipes that the fan must overcome. And another potential problem, if the fan would be too strong, would that interact with the various water traps (shower, sinks etc).
I do not think there will be a problem though, because if there were a lot of pressure inside the soil pipes system, you'd know about it every time you'd use your sink/shower etc and the solution is to vent sink/shower etc wastes. We had this problem here at my current house, where they plumbed utility and kitchen sink straight into the sewers, and that resulted in bad smells entering the kitchen, and I fixed it in two minutes by venting the sink waste just before it descended into the sewers.
Will building control accept it though?
