hi all, im a newby so forgive me if i make any boo boos whilst posting i am helping a friend install a central heating system and i have run into a problem on venting! the system is all on one level the cylinder is right next to the oil fired condensing boiler. as the flow and return pipes feeding the coil in the cylinder are lower than the outet flow and return on the boiler will i need to build in some air bottles at the high spots on the boiler. i already have a cold feed going into the return at the cylinder an air bottle to bleed the heating flow at the cylinder and an open vent on the flow at the cylinder where it goes ito the top pipe of the cylinder (i.e. DHWflow). i know this sounds complicated but when i have done instalations before its always been where the boiler has been lower than the cylinder like in a conventional house! this has got me flummoxed because its looking like i might have to put in two open vents if i cant use the air bottle system! regards, stanman
