Vents & Odours
29 Aug 2022
Hi, we’ve moved into our first home (the 1st & 2nd floors of a Victorian mid terrace). Unfortunately we didn’t realise the downstairs neighbour was the worlds biggest stoner when we bought, the seller masked it very well.
I’m waking up to the smell of cigarettes and weed on the top floor despite having a whole floor between us. I think the smell is coming through the vents on the old chimney breasts. Help please! Can I block these vents?
It’s also definitely coming up through the floorboard in the boiler cupboard, but that’s an issue for and other time.
Please send advice!
Do not block any chimney breast vents in any room.
Perhaps you could post pics of any chimney breast where there are: "vents on the old chimney breasts"?
Flues from rooms below you are not vented in your rooms.
Each flue is independent from fireplace to chimney stack terminal.
So most unlikely that odours from below are coming out of your flue unless the dividing wall between flues (the "Feather") is breached.
As its a new flat why not have all your flues swept and smoke tested?
Who owns the block? If smells are moving between what should be compartment walls and floors then that's a fire risk that needs dealing with by whoever owns the structure.
It's not a 'new' flat in the sense a modern one. It's 2 top floors of a Victorian terrace. i.e. over 100 years old probably.
Unlikely to be compartmentalised as it's such an old building. Certainly won't be any fire-breaks between floors where pipes and cables pass through.
To the OP. Are you sure it's the guy below and not someone next door? Sometimes floor joists in old buildings go into the wall and project under the next door floor. This can create gaps through the brickwork allowing smells to come through. Nightmare if you live above a fast food outlet sometimes.
I know its not a "modern" new flat as my whole post and last sentence recognised and implied.
Thank you for putting us all in the picture (y) Now we understand your thinking.
