Softus said:I believe that the cold supply to the shower is from the mains, whereas the hot water stored. Therefore a transient drop in mains pressure will not affect the hot pressure,
A transient drop in mains pressure WILL produce a transient drop in hot water flowrate. A toilet refilling, which I certainly wouldn't describe as transient (although in plumbing parlance perhaps transients last this sort of time, you tell me
althought it will affect the flow of mixed water from the shower head - this is because the flow of mixed water is an aggregate flow dictated by the 3.0 bar of mains cold and 0.3 bar of stored hot.
No, I meant what I said. As a human being, you will set your shower to about 40 degrees celsius. Mine is at 42, I like it hot. Now, your hot water pressure and temperature is constant, and will be about 60 celsius. Your incoming cold will be about 15-20 in summer, and as low as 3 or 4 degrees in winter.AdamW said:... the flow rate you experience will be proportional to the temperature of the incoming cold water.
Erm, not by the temperature, but by the pressure of the two supplies.
So in summer, your shower will be pumping through 1 litre of hot for very litre of cold to get a mixed temperature of 40. In winter, you will need nearly 2 litres of hot for every litre of cold. Now, with a significantly lower cold flowrate, the venturi assist to the hot water is also significantly decreased. Thus, your overall flowrate will decrease.
Erm, with at least two of the three products that I've read about (one of which I've installed), you can't turn down the cold as you would do on a conventional shower valve.
Well in that case I would like to see just how the hell they've designed the venturi to cope with such a wide range of incoming cold temperatures!
If you're talking about an instantaneous water heater type of electric shower, then I would expect one of this type would be worse than a venturi valve, because all such (electric) showers are quite poor.
I agree electric showers are pants, but I would have to try a venturi shower (good old Bernoulli!) before I'm convinced it is a danger to pump sales.
Although there is a minimum pressure at which they will work, yer actual flow from the shower head is a function of the power rating of the element and the specific rise in temperature needed,
Yeh, thanks, I'll just be sitting here in the corner with dribble coming out of the corner of my mouth occasionally shouting "DUUUUURRRRRRRRRRR!!!" and wearing a big gold badge saying "******". No, really, I hadn't figured that all out. Seriously, thanks Prof!![]()
I think I can now safely pass on my pedant's sceptre to Softus, knowing it is in good hands![]()
