You openly admit you know s** all and you prove it on a daily basis. A continuity test using an ohmmeter is a standard test. It sends a voltage down the cable and reads the resistance upon its return. Do you know anyfink?
oh dear, oh dear, oh dear
so mr invisible man - the op has dissed his cable in the PIR and the pair go open but when he reconnects them the PIR still doesnt trigger the panel even though the relay is changing
whats causing that then ?
Put that in English will you, there's a good chap.
Why don't you tell him?
I take it you know which zones the 2 u/s PIRs are on, if you (isolate first so it is running on battery power) take the cover off the panel, (you may need to enter your code as it will tamper). Pop a digital volt meter (needs to measure 12vDC) across the alarm terminals for the zones and get someone to walk in front of them. What happens - do you see a change in voltage?
Managed to test this at lunch time. Alarm panel is not far from the lounge PIR so managed to activate PIR and check the voltage. The voltage remains the same (Zero) when the PIR is active / inactive.
Guess this points to the cable...but why does the PIR still appear to work with the red light coming on once triggered?
OK, the wires should read about 0v when the PIR is not tripped and 12v when the PIR is tripped,
I think the next easiest thing to try is to disconnect the wires from the alarm terminals and see how many volts there are on the panel
terminals, hopefully there will be 12v which means the panel isn't at fault (and the link still isn't in from pre commisioning!!).
why dont you just accept youve no idea, continually post the wrong info and read posts incorrectly
all you do is wind the ordinary members of the public up - google the following " red and tube " it might be more up your street
You openly admit that you are clueless on technology - don't try and kid me you suddenly know something. You've never posted the right info yet.
no it doesnt - theres NO volts across the alarm terminals
The guy is messing with the programming and has stuffed it up.
There are usually 2-3 volts. How do you think it works then? Magic? Clueless as ever.
Not sure what I have started here - looks like WWIII!
So, no change in voltage on the PIR wires when the PIR is activated.
What can I test next?
