Today I noticed that the Pyronix PIR had a crack around the lower screw, when I opened it the plastic around the screw broke in small parts so I temporarly fixed it using a cable tie.
Now when I set the alarm it double-beeps (the PIR is the zone 2) as it does when there is a connection problem between panel and PIR.
But after it stops beeping the keypad indicates that the alarm is set. And the PIR does work correctly and triggers the alarm normally if I walk around.
Why the double-beeps then? I am not using the tamper connection for the PIR so the not perfectly close PIR body should not be noticed.
Thanks a lot for the help!
