I have a 3 vertical radiators which have baffle's fitted. A sticker label indicated this as did the MI's.
Flow or return sides is not an issue. At least not with the verts that I have.
Upgrade pipework?? Our plumber knew the plan to replace a standard horizontal rad to the vertical rad whilst we were redoin the kitchen, all he did was move the existing 10mm pipework along the wall about 40cm
Hi all firstly i would like to thank.all of you for our input. I did get panicy about your suggestions of10mm piping been inadequate for the rad but after messin around with the balacing as suggested it seems to have made a great deal of difference. The rad is now hot to the touch, although does seem to take abit longer than a normal traditional rad to heat up but that is something i can deal with.
So hopefully now i can put to bed the worries of an dodgy install.
