Hi all. Hoping for some advice.
I have s plan configuration heating system (oil) consisting of three 2 port motorised valves. Two of these are of type danfoss hpa2 for each of the CH zones, the other a tower for HW.
I have two room stats one for each zone, but I don't have a programmer/clock which can control each zone individually (if you get my meaning) so relay on stats clicking heat on/off in each zone.
Problems started about two months ago, following return from a fortnight holiday. Where neither heating or hot water was on
Firstly, the solenoid coil went at burner and was replaced, oil pump then went and was replaced then one of the danfoss actuator which controlled the valve body for one of the central heating zones stopped working and it was replaced also.
Now my heating system works fine for most part however some times, when I would select HW only and leave it on for say 30 minutes when I then switch off HW at the clock or cylinder hot water stat switches it off and I then were to switch on CH only for say 30 seconds, all my radiators in one of my heating zones will get very warm very quickly, almost like all the warm water from HW curcuit is getting into CH butthis only happens intermittently.
I'm by no means an expert in any of this and have done my best to try and research to this point it's just now I'm getting all sorts of different opinions from as to how to fix problem. Some are saying it's a microswitch on head of one of the CH zone actuators at fault, some saying valve body and head of HW needs replaced as bypassing, some even said it's wiring problem get an electrician. This has never been a problem before. and the only thing that had changed is that new actuator was wired in to replace one that had been failing to energise.
Really hope someone could shed some light on the problem.
Many thanks in advance.
