D
Deleted member 292770
chop chop the painters are coming.
If lack of time is your priority, thenThe solution you go with will depend entirely on your priorities
Plasterboard has its uses, it is a quick, simple and cheap solution that will give a decent finish; for now....
I didn’t say hygroscopic salts start in plaster.Well you've shown your remarkable ignorance yet again - surprise surprise, Hygroscopic chemicals dont start in the plaster - the chemicals begin in the chimney flue and continue being produced no matter how much plaster hacking off is done.
By the way, if no plaster board then which of these would you choose - gypsum - sand and cement - sand and cement and lime - sand and lime?
been here before and just as argumentative tel765you misunderstand me. i'm not talking about the corner damage but the contamination damage that can clearly be seen further back and lower down on the side wall and on the back wall.
Perhaps you dont realise it but you have been given pro advice!
I also said if you cant cancel leave the corner for later i also expect you will still be alive when the easifill fails "EDIT"can we see pics of finished job?Hi.
Sorry for the late reply. Thanks for the comments. Cancel the painter!? Are you going to tell her?!
The painter has been. Bless him he chucked a bag of easyfill into that wall and painted it! never had the conversation about repairing it as I was keeping out of it so this repair will have to wait as she doesn't want the paint touching now it's on.
If anyone is still alive when it gets redone I'll post up what we did!
On with the next problem but I'll start a new post.
It's only going to take a few minutes to knock the filler out and get back to brick so I'm not too worried.I also said if you cant cancel leave the corner for later i also expect you will still be alive when the easifill fails "EDIT"can we see pics of finished job?
what you want to see it for? you’ve already pulled holes in it because he didn’t bow to your superiority? And you haven’t even seen it.I also said if you cant cancel leave the corner for later i also expect you will still be alive when the easifill fails "EDIT"can we see pics of finished job?
Don’t waste your time taking photos fella, they just want to pick holes in it. It’s good enough for you and your mrs and good enough for xmas , so fuk em.It's only going to take a few minutes to knock the filler out and get back to brick so I'm not too worried.
I could post some pictures but I feel like I'm doing the painter a dis-service when he just patched it up to try and help and everyone starts laughing! It's not pretty and probably won't last but the room is painted ready for xmas and the nags have stopped so I am moving on for now.
I think a bull nose finish would look nice when redone also.
