- Joined
- 14 Jun 2021
- Messages
- 4
- Reaction score
- 0
- Country
I've had a 200W Viessman boiler for about a year. As the boiler goes it is not bad but the installation is a bit rubbish.
I went through the Viessman website and used the guy they recommended to do the job. Since the boiler has gone in I've had leaking pipework under the boiler I think. The rest of the pipework was pressure tested, new cylinder, pressure flush etc, prior to putting the new boiler in. The guy who did the install basically refused to come back and fix it.
I've had another Viessman engineer come out. He looked at the install and spent a lot of time swearing about the quality of the workmanship of the installers. Since he looked at the system my heating comes on at the same time as the hot water. Not great in this hot weather. I don't think the problem is the fault of the second guy, more the Jenga tower left by the installer. He did tighten up some pipework under the builder, which might have solved the leak.
I've contacted Viessman, who just stick to the line that their installers are independent contractors. I've even had them do the 1-year service but they refuse to help regarding the installation of the system. Just stick to the line, we just sell the boilers.
At the moment I'm considering ripping out the Viessman and putting in a Bosch. At least there seems to be good knowledge of them in the trade.
Happy to supply any details of the install. I'm trying to work out whether to persist with this boiler and what needs to be done to get it working right. I can probably supply diagrams of the system install and wiring.
