That link is not for a WB1B compact model.
I know, the op hasn't mentioned having the compact model and also
The wiring connection page 14 etc
connection details are on page 13 of the compact model
but seeing how he mentioned the stats listed on 42 where as they're on 41 you could well be right,
you wire them the same way anyway!
Hi all, sorry for the very late reply.
You may remember that i had problems fitting the 2x channel digital timer to my 26kw open vent Viessmann Compak WB1B as i could not find the switched timed outputs!
After contacting Viessmann for a second time and talking to another engineer he told me that the digital 2x channel Viessmann timer does Not in fact fit to the compact open vent and you cannot fit the timer to this model.
I told the engineer that the timer is listed as an accessery by Viessmann and the box is ticked for it to be fitted to the Compak, this is a Viessmann error in their listings and explains my problems fitting the timer.
However, as the timer fitted perfectley into the boilers front panel and plugs into the pc board where it picks up 24vdc i decided to use it by fitting 2x 24vdc relays (one for each channel) into a small ABS box and use the contacts of the relays to switch the 240vac to run the boiler, i know that this may be outside some fitters technical capabillities but if anyone wants to use this timer be aware that it switches the `0` volts lines from the timer Not the +24vdc line, i nearly gave it up until i found how the signals were being switched.
Thanks all, boiler working fine, i may need to do a plumbing modification as i think the hot water is shorting around the bypass loop and telling the boiler to shut down? i have tightend the bypass valve right down (.5 bar) and have balanced the rads to get the best results but they are not as hot as the old oil boiler got them and it was only half the power of the Viessmann.
Could i fit an electriclly operated shutoff valve in place of the bypass? it would need to be normally open and when either motorised valve opens it would close!
Thanks for any replies, and lets have a happy warm New Year
Kind Regards
