I've been speaking with my plumber and also with Viessmann and appear to be getting different answers, so wondered if anyone had any thoughts.
Looking at the Viessmann 200 system range, the modulation range for the 26kw and the 35kw appear quite different, with them both going down to the same lowest level (spec attached):
5.2 - 26 kW
5.2 - 35 kW
The plumber says this is a mistake, and Viessmann say the tech details are correct. I've looked at the various sites for different regions and it follows in all.
There's a negligible difference in cost, so if I were to go for a 26kw, is there any reason not to spec the slightly higher for the 35kW and presumably get a slightly faster DHW heat up time?
Thanks.
5.2 - 26 kW
5.2 - 35 kW
Thanks.
