Hi there, I have recently had a sevice on my boiler following the following faults:
F4 error - got this resolved with Viessmann which was great.
F5 error - got this resolved in the service and saw the flap that got "stuck"....what a design!
Now after these annoying "issues" that happen after a few years of use are concerned being resolved, I have now found that whilst no fault codes are being reported, the hot water when on (all round the house) is heating up and then at temp 86 degrees the boiler stops to minimum water heat then starts back up at approx 72 degress back to 86 approx.
I have contacted the chap who serviced the boiler and he says that I need to throttle back the taps as the flow is too much for the boiler to cope with.......however I cannot see this as correct as I have tested with the taps at 1/4 turn which surely has the same effect....? It did the same thing with the 1/4 turn, we never open the taps fully anyway.
This did not happen before the faults I had reported and fixed and the service to resolve the flap problem.
I was wondering if anyone had any advice, and could confirm if the plumber is correct and I need to restrict the water flow through the taps!?
Can anyone shed any light on the issue and or if the plumber is correct?
Is this a part at fault or is this correct behaviour and down to water flow rate?
Cheers
Andy
Cheers
Andy
