I call(ed) them pattresses. I fitted some wall lights in my living room a couple of decades ago, they had just a bare gold coloured metal base to fix to the wall, which I thought would look simply wrong - so I turned up some fancy wooden pattresses from some scrap wood. I used a drill, clamped in a vice, with a long bolt through the middle of the wood block, plus sharp chisels to turn the block to shape and varnished them. I still have those wall lights and pattresses up, though now converted to LED.
I also have a 13amp plug identical to cwhaley's rubber plug. Its on a very old extension lead I used to use in my garden.
I have an oldish 1200amp clamp meter I bought in the late 1970 for big pump motors, several Avo 8's and a AEI(?) Selectest. I just keep them for old times sake, as they were what I was brought up on. I really couldn't wait to move to the digital meters quick enough, when they appeared, buying one of the Sinclair LED meters.
Managed to find 5 minutes to take these. The last one is a 'fairly' modern one though it was last calibrated in 1992. LOL
The close ups are to show the ranges.
