Hi, I have moved into a large 4 bed 3 bathroom house recently and it had a Vitodens 100 boiler fitted new about 15 months ago (with no documents). An engineer has replaced the pump with a Grundvos and I have had it serviced and checked by 3 engineers. There are 14 radiators (6 down, 8 up) but none ever get very hot, lukewarm at most. Most of the rads are small / double but there is one 2m double radiator that never gets very warm in particular.
All have been balanced and bled. For example, this morning despite the heating being on 2 hours solid, I can't get it warmer than 19c. I have new top spec windows, 300mm of loft insulation and foil behind the rads.
My question is:
Do you think the Vitodens 100 is powerful enough for 14 rads or did the previous owners put in a lower spec boiler cheap so they could still sell when the pervious boiler went wrong?
I have been told to look at the data badge on the boiler which will tell me what the output is(on the top to the right of the flue outlet) but I'm not sure if I have to take it to pieces to do this.
[email protected]
My question is:
[email protected]
