I've tested it a little furtehr following everyone's advice and found:
If I turn the boiler up so it's heating to about 70c and reduce the temp gauage on the tank (down to say 50c, it clicked on the way) after about 2 hours I noticed that both the pipes going in to the side (top and bootom) were both still hot and the temperature on the tank was about 70c. I know this as when I was moving the temp gauage back on the tank I moved it up to see what temp was it clicked out at.
Does this mean that the 3 port valve might not be working correctly and giving too much hot water to the boiler rather than the rads? It is an original valve and I've notice the rads occasionally get slightly warm in summer when only the hot water is on too.
I assume it will be a fairly quick cheap job for a heating engineer to replace this?
