Hi again, my mistake, English is not my daily language, on my 08 primastar the alternator was causing the problem, now i did the same thing but no luck.
Checked the followins:
Fuel is ok, pump is working, fuel comes on the ramp and returns back whend cranking, changed even the fuel filter.
Changed:
Crankshaft sensor
MAF
Glow plugs relay (the module)
Glow plugs
Checked the harnest (seems ok)
Cleaned all the negative conections on the chassis and gearbox
Cleaned egr
Checked the glow plugs Cables = ok
Tryed start by towing + crank = no result
Tryed start with help of startgas (i know it's not good for a diesel) , it starts but Engine dies after 2 seconds.
Still have following: imobilizator light = solid red
Stop ligt = solid red
No light what so ever for glow plugs
Battery light = solid red
Get following codes :
P0670 - Glow plug Control module Contro Circuit / Open
P0110 - Intake Air Temperature Sensor 1 Circuit (Bank 1)
P0100 - Mass or volume air flow "A" Circuit (Bank 1)
It is strating to get on my nervs now. Forgot to mention Engine spins smooth and sounds normal when it cranks.
If you have any suggestions don's hesitate to write them
