Void behind dot and dabbed backer boards?
6 Oct 2014
Cambridgeshire
Will the voids behind dot and dabbed backer boards cause any problems or cosmetic issues once tiled and used in a bathroom?
Will the dabs be cold bridges to the masonary wall for example?
Is there any solution, or is this not an issue?
Mapei Super flexible (standard set) - you then use plastic dowels, screwed through dabs and wall to mechanically fix them in place.
