Air pressure switch can be dropping out. Does the main burner come on at high, not drop to low rate but go off - then after short while, reignite at high again? Quick tip on most of Vokera range for this type of problem, loosen the combustion cover (either 2 bottom spring clips or 8 screws) just enough to get a bit of additional air drawn into the combustion chamber (crack open the combustion cover a couple of centimetres at one corner). If appliance remains on and modulates high-low-high in response to DHW temp, then prime suspect is fan venturi slightly choked, or choked fan blades (very little build up on this can cause problems. I agree with everything everyone prior to me has said, but try this to disprove the APS first (easier than descaling a plate).
