Start from scratch New Vokera Linea 28 boiler / pipework kitchen and bathroom fitted 2007 .
So from day 1 slight knock in boiler and pipework when turning off taps or washing machine ends. Now over the years developed into a bang in boiler and all pipework. 22mm boiler to bathroom turn off taps slowly still bang but not as bad. Fitted water hammer arrester after main stop tap cold feed no change. Bought remote expansion vessel to try
Also a Rattle sounds like carbon particles in pump when running.
Stripped and cleaned Pump, Float Expansion vessel braided pipe nothing excessive found Removed pipe from gas valve to combustion chamber and blown out. Brushed & vacuumed combustion chamber and all internals. Spiders and dust etc.
Listened with bar to ear loudest from DHW heat exchanger
Plus periodically boiler will be working fine then won't fire up but sounds like a machine gun (think coming from gas valve but not had casing off when it occurs) Turn off reset 1 minuet turn on fires up as normal then be OK for 10 mins / 2 hours or even a month no set period.
Fernox F1 fitted 2013 to return before boiler (not collecting any debris)
No forums over the years list any of these faults any HELP would be most welcome
