scatmanjohn said:When you move the seletor knob to the middle does the display go blank or does the 01 code stay lit?
Goes blank as though it is "off" Then looks promising until "01" appears.
scatmanjohn said:Have had a few non resetting faults which were sorted with a dispaly pcb.
Looks like you will have to raid the piggy bank again
nortimax said:scatmanjohn said:Have had a few non resetting faults which were sorted with a dispaly pcb.
OK thanks for the cure but what is going to happen if the gas has to be turned off again? Which circuit board needs replacing the knob/ display or/and the main pcb? What will happen if a different lockout occurs? Starting to wish I'd had a halstead ace installed instead of this cheaper one
Actually it stays flashing at 01. Just replaced the board and its up and running. Thanks to all for your help.scatmanjohn said:When you move the seletor knob to the middle does the display go blank or does the 01 code stay lit?
nortimax said:Actually it stays flashing at 01. Just replaced the board and its up and running. Thanks to all for your help.scatmanjohn said:When you move the seletor knob to the middle does the display go blank or does the 01 code stay lit?
scatmanjohn said:nortimax said:Actually it stays flashing at 01. Just replaced the board and its up and running. Thanks to all for your help.scatmanjohn said:When you move the seletor knob to the middle does the display go blank or does the 01 code stay lit?
Well if it stays at 01 when you move it to the middle it means that you are not resetting it.
So, if the knob is intact (are you 100% sure, cos you have already changed your mind about one thing) i would say the fault is with the display pcb, thats the one that does the resetting.
Try turning the gas off under the boiler whilst its running (yellow tap).
My money is on it not resetting.
scatmanjohn said:Have you tried turning off the gas yet to see if it will reset afterwards.
scatmanjohn said:What i am trying to tell you is that i think you have waisted your money on two pcb's.
Alright, its got your boiler out of fault condition but thats just hiding the true fault.
The reason a new pcb works is because it is not in a fault condition when supplied so does not need any resetting.
IMHO
IMHO
I have an easy way to find out
IMHO
scatmanjohn said:I have an easy way to find out
i have an easier way,,go turn of the gas and see what happens
If the display is staying on ,even when the knob is in the middle position it is not resetting.
