vokera linea
12 Nov 2009
Hi i have a vokera linea standard efficiency combi boiler, central heating is working fine but when i change to hot water mode and run a tap the water keeps going hot and cold hot and cold and so on. Any help what might be going wrong with my boiler? Thanks
But if the thermistor was fecked or out of range should the boiler not fire at all on sensor check?
I will check resistance with multi meter if this is not the problem any other likely causes that i can check while im at it. Thanks
Plate heat exchanger is blocked. Very common on the linea. The waterways are quite narrow compared to some.
A fault with the HW sensor generates a fault code.
not always, the primary gets coated in the same **** as the h/e does and doesn't read temps right. the dhw can be faulty without flagging a code.
as a rule if an h/e is blocked i change the thermistor. saves coming back later.
