Hopefully someone can offer some advice.
An intermittent fault occurs on my boiler whereby the boiler will not start even though the programmer and thermostats are calling for heat. I have checked all the voltages and they are correct going into the boiler.
When the boiler is turned off and on again the boiler starts. There has been no error code. Spoke to vokea who said it was the main PCB so I changed it but the problem still persists. Called vokera back but they said call an engineer.
Unfortunately I currently cannot afford to do this although I acknowledge this is sound advice.
I am however pretty competent at fixing problems and am not toching the gas side of things so would like to try and fix this myself.
A development today has been that when I went to restart the boiler again there was an error code 2 that pointed to the boiler having overheated. Interestingly I had the night before just turned the heat setting up to max on the boiler. I wonder if this had highlighted the problem.
Could the thermistor of thermostat be the problem here. I assume that both of these could stop the boiler firing if they think the boiler is up to temperature. I guess the pump is not running because it has overun and stopped?
Any advice would be greatfully received.
