VRC430, VR61 & VR81 - 2 Zones, both Modulating?
so what happens when one zone calls for higher flow temperatures than the other...
I think you will find the 430 will determine the highest flow temp...as the vr 81 will think it is on a mixer, and running in a lower heating curve...
viessmann or vaillant, the only way to compensate two zones with the same type of heat emitters is to use electronic mixing valves...anything else is a compromise...
