Hi, I have a 1.4 litre 97 polo 98500 miles on the clock, which has suddenly developed sticky gears. It has always been fine until 2 days ago and now I am finding it difficult to get it into gear without a bit of a rough hand! I'm not sure if this is a gearbox issue (oil?) or a clutch issue but basically I had a new clutch fitted about 7-8 months ago after the last clutch had gone. After about 2 weeks of having the clutch replaced the car developed a very slight whirring noise (which I was told not to worry about ) and this noise has progressed from a whir to well its hard to say but its quite noisy and when you put your foot on the clutch it stops when you take your foot off it starts again. So with this current problem of sticky gears what could be the issue causing it? Any ideas? Thanks!
