My mother has the above boiler which was installed in 2000 and serviced up until last year by British Gas. Sod's law it started misbehaving just as she came out of homecare or w/e they call.
No matter CH or DHW it would struggle to heat up from cold; making slight booming ignitions, ignition sparking when flame visibly lit, solonoid clicking, flame light on and off, sometimes even ignition lockout, would happen for a couple of minutes until it warmed then it would run no problems.
Friday morning she did the washing up and shortly after went to turn on the CH when she heard a horrible noise coming from the boiler and quickly switched it off for fear of it blowing up.
I have since tried the DHW and it sounds exactly like this but louder and continuous and ends with the boiler not firing and flashing: Air flow fault.
I am trying to find out the fault/s, a rough estimate on repair cost and also opinions on if it would be better to replace altogether?
Thanks for your time.
