W/B 26CDI XTRA, Hurrendous noise, air flow fault.
You are fiddling with things you are ill equipped to be fiddling with.
the broken blade won't be causing your problems, but you need a qualified engineer to be looking at the boiler.
I'm not getting into a dispute about whose equipped to be doing what here.
The engineer said it wanted replacing; I don't have a spare 2K lying around hence exploring other avenues.
Would the W/B fixed price repair be worth a try?
fair does! for your info WB dont cover the flue in any way shape or form, but will sort the boiler
Looking at the flue I cannot see why the engineer suggested it was shot, I cannot see any rotten bits, holes etc. There is a large clip on a seal which looks like it should have a nut/bolt on it (possibly what damaged the fan blade) and a further double clip lower down which looks rusted. I'm guessing they would replace these?
Well he was right, the flue elbow has a hole like a coin slot in it.
I think I'm stuck with two options now.
1. Help Link, or
2. Get someone in to cap off the gas so I can remove the old combi. Stick new combi + bits on credit card and pay for install.
